It is currently Mon Aug 04, 2025 1:00 am
PostPosted: Wed Feb 04, 2009 9:23 pm
I need four six inch round flanges with a 3/4 center hole. I have searched heck and high water and come up empty. The 3/4 center hole keeps me locked out. Every time I find some, they have 1 to 1.5 inch center holes. These are safety flanges for a buffing arbor to cover the metal collecting ring found on most "airway" style buffing wheels. I am stepping up to some 16 inch wheels on my slow machine to increase surface speed and the collector ring is 5 inches therefore I need the six inch flanges. A nice 3/16 thick washer will even work. If it weren't so cold, I would just pull out the plasma cutter and fab up my own. Too stinky to use inside the shop, I hate the smell of burning metal. [xx(] I know this doesn't really pertain to building but I didn't think it fit any where else.
jw ( o)===:::
PostPosted: Wed Feb 04, 2009 9:42 pm
got a local machine shop who could zip them out on a plasma table for you Joe?
Would aluminum work if 3/8 thick? Might be able to cut them on your bandsaw (if you have one, I think you do) then drill your 3/4" hole.
PostPosted: Wed Feb 04, 2009 11:05 pm
I did contact a local tool and die and they want $100.00 for four of them. Seemed a bit steep. Your right, I could fab them up with aluminum too.
jw ( o)===:::
PostPosted: Wed Feb 04, 2009 11:10 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
How about working them up from something like this?
http://www1.mscdirect.com/CGI/NNSRIT?PM ... O=57837512
http://www.PeakeGuitars.com
PostPosted: Wed Feb 04, 2009 11:11 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Never mind...just saw that is stainless...! Probably a little bit tough to cut...
PostPosted: Wed Feb 04, 2009 11:19 pm
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
I have a friend that works a a pipe supply house here in Houston who could get you some carbon steel pipe flanges that you could drill. But remember that a true pipe flange will be about 1/2" to 5/8" thick in that diameter. Aluminum might be your best bet. Just add 50% to the comparable steel thickness (say 3/4 instead of 1/2 or 3/8 instead of 1/4").
Also, consider that your flange needs to be balanced to keep from inducing bad vibrations. As opposed to the Good Vibrations of the Beach Boys.
edit add on - If you know someone with a metal lathe he could make a set in a snap.
Hope this helps,
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Thu Feb 05, 2009 7:21 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
You can do a static balance by simply setting the wheel up on an axle and seeing where the heavy spot is and then drilling a little material out at that point.
